Home » Audio » Speaker » Finally Building Full Range Single Driver Speakers
Re: Finally Building Full Range Single Driver Speakers [message #60821 is a reply to message #60820] Thu, 10 September 2009 12:57 Go to previous messageGo to previous message
Skip Pack wrote on Thu, 10 September 2009 12:35
Hey Fred,
While you're at it, you could elaborate by building an
offset bipole using Bob's geometry and tuning and Duke's
Dream Maker concept with a nod to Jim Griffin. Keeping life
simple, of course.
It sounds like you are back toward the high sensitivity
side. How would you compare your lower sensitivity/more
conventional efforts -- is it as simple as lower coloration
versus better dynamics?
Hope all's well,
Skip
Sorry, Skip, the speaker you described in the first paragraph above sounds too simple, so could I make it an offset bipole MLTL line array? Actually, there are some effective meds for bipolar people like Duke, except that occasionally they become schizophrenic, believing they are surrounded by a swarm of little subwoofers or something equally delusional.
High sensitivity not! The typical 95dB sensitivity full range single driver offers that sensitivity only above 1khz, so you need a BSC filter to tame the highs, taking it down to the 90 to 92dB sensitivity range. Not a problem if you've moved all your tweekie/deekie little SET amps to a closet and replaced them with a real amp like a Krell.
Previous Topic: MTM horizontal arrays
Next Topic: Dipole/Bipole Transmission Line
Current Time: Sun Nov 15 23:07:49 CST 2026
