Home » Audio » Speaker » second array already in the works
Re: second array already in the works [message #60738 is a reply to message #60730] Tue, 01 September 2009 11:24 Go to previous messageGo to previous message
Villain3g is currently offline  Villain3g
What did you end up with for spacing on your tweeters. Seems like 30 wouldn't be long enough, especially when modified. Do tweeters line not have to be as long a woofer lines?
Do you have any pictures of arrays that you've built?
When looking at the technical drawing of the Tang Band 13-1264SA, it actually looks like they can be cut down to 21mm. What are your thoughts? index.php?t=getfile&id=55&private=0index.php?t=getfile&id=54&private=0
  • Attachment: untitled.bmp
    (Size: 624.08KB, Downloaded 3624 times)
  • Attachment: untitled2.bmp
    (Size: 683.17KB, Downloaded 3574 times)
Previous Topic: Comb Filtering Misconceptions
Next Topic: Dedicated horn loaded mid -- big disappointment.
Current Time: Fri Oct 16 12:18:30 CDT 2026
