Home » Audio » Speaker » 8 ohms speaker on 4 ohms stereo
8 ohms speaker on 4 ohms stereo [message #60733] Tue, 01 September 2009 09:53 Go to next message
Mortaric is currently offline  Mortaric
I have a little 40W 4 ohm bookshelf stereo. I was thinking of hooking up a pair of small 8 ohm 15-100W speakers that are sitting in my basement. Will this work or will it be damaging to the stereo or speakers?
Re: 8 ohms speaker on 4 ohms stereo [message #60734 is a reply to message #60733] Tue, 01 September 2009 10:29 Go to previous messageGo to next message
That will work just fine. When an amplifier is rated 40W at 4Ω, that tells you that anything above 4Ω won't draw excessive current and that it will develop 40 watts with a 4Ω load. If its a solid state amp, I wouldn't go below 4Ω but 8Ω is just fine. It just won't develop quite as much power into an 8Ω load. If it's a tube amp, I might not go above 16Ω but if solid state, higher impedance loads won't hurt. It just won't be as loud with a higher impedance load.
icon14.gif  Re: 8 ohms speaker on 4 ohms stereo [message #60743 is a reply to message #60733] Tue, 01 September 2009 21:46 Go to previous message
Thanks I hooked them up and it sounds great. Very Happy
Previous Topic: Smoothing Effect on FR of multiple speakers
Next Topic: Marlboro's Line array is still purchase-able
Current Time: Thu Nov 12 16:08:28 CST 2026
