Home » Audio » Speaker » using a wall of 15" woofers for bass.
using a wall of 15" woofers for bass. [message #60621] Tue, 18 August 2009 02:16 Go to next message
noviygera is currently offline  noviygera
I have this idea to make a wall of woofers as a sub.
Lets say the wall behind my main speakers is 82" high x 86" wide. Speakers are placed about 5 feet into the room.
I can make a fake wall (big panel) that's 70" x 80" and 12" into the room. Essentially a big open baffle panel that's a foot from the wall. Then mount 5 15" woofers spaced closely from top to bottom (checker board pattern) behind each speaker.
Having a total of 10 15" woofers.
Woofers can be cheap 15" with Qts of about 0.6. and Fs about 30Hz, 93 db efficient. (around $20-$30 each on parts-express)
Anyone try this?
Is this a good idea to make good flat in room bass response?
Will there be a noticeable delay between wall woofers and mains?
How high can I crossover to mains? 70Hz? 120Hz?
-Herman
Multisubs [message #60623 is a reply to message #60621] Tue, 18 August 2009 10:12 Go to previous messageGo to next message
I think it's a good idea. Do a search here about multisub configurations.
Re: Multisubs/open baffle [message #60637 is a reply to message #60623] Thu, 20 August 2009 21:38 Go to previous messageGo to next message
Did a search, read the articles downloaded "Edge" program to do a simulation. I ran into three issues:
1. My open baffle can be as tall as the basement height allows and therefore it can stand on the floor and go up to the ceiling, like a fake wall, making a vertical "short circuit" in the room. How do I properly enter this into the Edge program? "infinitely high and low baffle"?
2. The open baffle can be as close to the rear wall as the driver/mounting allows. What kind of effect will this have, do I need to somehow compensate for this effect or take into account when modeling in Edge? And will this work?
3. I can make the open baffle slightly LESS wide than the rear wall. I was thinking of making the open space to be the area of the driver cones. Is this a good idea?
Thanks,
Herman
Re: Multisubs/open baffle [message #60638 is a reply to message #60637] Thu, 20 August 2009 22:54 Go to previous messageGo to next message
I don't use EDGE, so I'm no help there. Hopefully someone else that has experience with this program will chime in.
Re: Multisubs/open baffle [message #60639 is a reply to message #60638] Thu, 20 August 2009 22:57 Go to previous message
Maybe this is the case where I just follow my instinct, build my idea and report the result. Will do Smile
-Herman
Previous Topic: Basic requirements for phase plug in horn loaded cone driver?
Next Topic: Need suggestions for a lower range horn to mate with new Mid/High horns
Current Time: Fri Oct 04 07:55:34 CDT 2024
