Home » Audio » Silicon Valley » Marshall AVT100 Problems (Effects)
Re: Marshall AVT100 Problems [message #60614 is a reply to message #60613] Mon, 17 August 2009 08:51 Go to previous message
Sounds to me like it might be a cold solder joint or mechanical connection. I would re-heat every solder joint and flow in a small amount of new solder. I would also reseat every mechanical connection and socketed component by removing and reinserting them. Start with that, it may fix the problem.
Previous Topic: Distortion
Next Topic: plans for single frequency electronic crossover?
Current Time: Sat Sep 05 15:53:53 CDT 2026
