Home » Sponsored » Pi Speakers » 7-Pi 10 inch mid ?
7-Pi 10 inch mid ? [message #60599] Thu, 13 August 2009 17:19 Go to next message
was the JBL 2012h midrange a good choice for the Pi-7 ? THANKS
Re: 7-Pi 10 inch mid ? [message #60600 is a reply to message #60599] Thu, 13 August 2009 23:20 Go to previous messageGo to next message
OK ,let me rephrase that . Does the jbl sound clearer than the delta 10 and the alpha 10 when used in the midhorn ?
Re: 7-Pi 10 inch mid ? [message #60601 is a reply to message #60599] Fri, 14 August 2009 09:08 Go to previous message
Yes, the 2012 is very good. It rolls off above ~1kHz and that's perfect for use in this application. The Delta 10 reaches a little higher but you roll that off with a series coil in the crossover. In general, the midhorn was designed to cover the 200Hz - 2kHz decade, but you really only need it to reach ~1kHz to sum properly with the tweeter.
Previous Topic: Harmonic Distortion
Next Topic: Four Pi Driver Spacing
Current Time: Thu Oct 29 11:07:32 CDT 2026
