Home » Sponsored » Pi Speakers » 12Pi is a 4 ohm speaker?
Re: 12Pi is a 4 ohm speaker? [message #59615 is a reply to message #59439] Sat, 04 July 2009 04:29 Go to previous messageGo to previous message
MArz is currently offline  MArz
Dear Wayne,
Thanks a ton for the plans. I have a few suggestions.
Could you not mount 2 sets of castors on the back panel and 2 conventional speaker handles on the top and 2 on the bottom panel in the place where you've cut out for the placement of your handle on one end and the castors on the other? this would really help when you need to physically lift the speaker over say a ledge in a doorway. also then one could just rest the speaker on its back and roll it to the van or to the venue....
Just a thought..
Also the mating of the panels seems to be done just flat joint. Isnt there a need to have a tongue and groove joint especially in the the mating of the main speaker box panels?
Thanks a ton anyway....
MArz
Sometimes You gotta say "What The Fuck"!
Previous Topic: "Feelin good, walkin' tall; ya think I might be officer material?"
Next Topic: Converting 3 Pi to 4 Pi
Current Time: Mon Oct 19 04:48:43 CDT 2026
