Home » Sponsored » Pi Speakers » 4PI plan with JBL 2227 & Altec 909-8A on 811B
4PI plan with JBL 2227 & Altec 909-8A on 811B [message #59577] Wed, 01 July 2009 11:15 Go to next message
krazylek is currently offline  krazylek
Hello Wayne, could you send me the plans of the 4 PI ? Is there any modification to do if I use them with the horn outside the box ? And finaly do you recommand a value for the (active) crossover cutoff for my speakers ?
Thank you !
Benoit
Re: 4PI plan with JBL 2227 & Altec 909-8A on 811B [message #59580 is a reply to message #59577] Wed, 01 July 2009 14:19 Go to previous messageGo to next message
I own a pair of 811's and love them for nostalgia's sake. They sound nice on axis too. But I do not have any designs that use 811 horns. All my designs use either the H290 or my own wood horn. These are much shorter than the 811, and that's a very important consideration in crossover design. They also provide much more uniform directivity, so you'll probably want to build the speaker as designed.
Re: 4PI plan with JBL 2227 & Altec 909-8A on 811B [message #59582 is a reply to message #59580] Wed, 01 July 2009 15:26 Go to previous messageGo to next message
If I don't use any mid/high speaker in the 4PI enclosure, the original design and measures are still correct ?
I would like to simply put my horns on top of the pi speaker, is it possible or should I use another cabinet design for the 2227 ?
Thank you
Re: 4PI plan with JBL 2227 & Altec 909-8A on 811B [message #59586 is a reply to message #59582] Thu, 02 July 2009 00:11 Go to previous message
You can use the 2227, but you can't use the 811. It's just too different and won't work with this design.
Previous Topic: Help please ... from the bottom up
Next Topic: 2 Pi Tower Plans
Current Time: Sun Nov 29 13:20:55 CST 2026
