Home » Audio » Speaker » Need suggestions for a lower range horn to mate with new Mid/High horns
Two midbass horn layouts... [message #59563 is a reply to message #59521] Tue, 30 June 2009 21:25 Go to previous messageGo to previous message
noviygera is currently offline  noviygera
While trying to figure out HornResp, I came up with two midbass horn layouts. The question is weather they will work in my setup, so I included both sketches.
1. Midbass ABOVE the midhigh, coupled to the ceiling: available area: 12"x34" mouth, 30" depth.
(option1.jpg)
index.php?t=getfile&id=38&private=0
2. Midbass VERTICAL, below the midhigh. I was inspired by this JBL horn:
http://www.jbl.com/home/products/product_detail.aspx?prod=1400%20ARRAY%20BG&Language=ENG&Country=US&Region=USA&cat=BFS&ser=PTS
Can this be made to cover 90 deg horiz x 25 deg vert? By stretching out the throat to be tall and narrow?
(option2.jpg)
index.php?t=getfile&id=39&private=0
Thank you.
Herman
  • Attachment: option1.jpg
    (Size: 311.38KB, Downloaded 8884 times)
  • Attachment: option2.jpg
    (Size: 250.83KB, Downloaded 8062 times)
Previous Topic: using a wall of 15" woofers for bass.
Next Topic: Maggie in High Heels
Current Time: Mon Sep 28 11:06:59 CDT 2026
