Home » Sponsored » Pi Speakers » Theater four (response curve)
Theater four [message #59547] Sun, 28 June 2009 18:26 Go to next message
Can the 4-Pi x-overs be used with the Delta-15 ??? Or do you change the 6.8 uf capacitor to 8.2 uf ??? Thanks.
Re: Theater four [message #59548 is a reply to message #59547] Sun, 28 June 2009 21:59 Go to previous message
I haven't made the Theater Series four π speaker in quite some time so I don't actually know. But I expect the crossover for the current model four π would work very well with it. The current model uses Omega 15 or JBL 2226, previously called Stage or Professional Series, respectively. The drivers and physical spacing are similar and the horn is the same.
Previous Topic: Lascalas again !!!
Next Topic: B&C ME45 aluminium horn
Current Time: Sat Nov 28 17:39:50 CST 2026
