Home » Audio » Speaker » Need suggestions for a lower range horn to mate with new Mid/High horns
Re: Need suggestions for a lower range horn to mate with new Mid/High horns [message #59523 is a reply to message #59522] Thu, 25 June 2009 16:26 Go to previous messageGo to previous message
noviygera is currently offline  noviygera
Wayne,
It's NOT possible to install horns near corners of the room. So no corner gain, but I wander if I can couple the midbass to the ceiling?
what do you think about my coaxial "horn within the horn" sketch? It's attached to the post.
The small horn would be mounted in the big horn. If crossed at 500 to 600 Hz would it work? dispersion problems happening here?
Theoretically, the midbass horn would be 18" wide, like the high horn, but tall, about 35" high, coupled to the low ceiling of my basement.
-Herman
Previous Topic: using a wall of 15" woofers for bass.
Next Topic: Maggie in High Heels
Current Time: Mon Sep 28 05:29:47 CDT 2026
