Home » Sponsored » Pi Speakers » Active Theater 4 Bi-Amping
Active Theater 4 Bi-Amping [message #53517] Tue, 12 May 2009 06:14 Go to next message
peppennino is currently offline  peppennino
Good moornig, Wayne.
I'm considering the opportunity of bi-amping my Theater 4 (my 300b set for the PSD2002 and a solid state amp for the Delta 15). Have I remove the whole passive filter or I have to add some equalization network?
The active Xover probaby would be built with tis project:
http://sound.westhost.com/project81.htm
With a 12 db slope for the compression driver, have I change the crossing frequency (higher)?
Many many thanks in advance,
Vincenzo
Re: Active Theater 4 Bi-Amping [message #53518 is a reply to message #53517] Tue, 12 May 2009 11:39 Go to previous messageGo to next message
I think active crossovers are a great idea, but you'll need to copy the filters exactly for proper summing.
I have another suggestion: Split the subwoofer output instead of the midwoofer and tweeter. Run the mains on one amp and the subs on another. That way you can leave the optimized passive crossover in place, and use the woofer amps for subs.
Re: Active Theater 4 Bi-Amping [message #53521 is a reply to message #53518] Tue, 12 May 2009 14:25 Go to previous messageGo to next message
Thanks, Wayne. Maybe an alternative setup would be adding a midbass horn similar to that of Th7 and use the other amp for the sub?
It's the same thing that one of my friends is doing on his Theater 6..
Re: Active Theater 4 Bi-Amping [message #53523 is a reply to message #53521] Tue, 12 May 2009 16:52 Go to previous message
Yes, that's a good way to split them out. It would be pretty easy to amp the woofer separately from the mid/tweeter in a π cornerhorn. Same idea as the sub/mains split I mentioned in the last post. That way you keep the passive crossover that's used in the mid/tweeter region, because it is already optimized and might be hard to duplicate with off-the-shelf crossovers.
Previous Topic: Speaker over damping !!!
Next Topic: How high does the pi 7 bass horn go?
Current Time: Sun Jul 14 04:09:06 CDT 2024
