Home » Sponsored » Pi Speakers » Multi-sub Crossovers
You've got mail! [message #53453 is a reply to message #53450] Mon, 20 April 2009 18:33 Go to previous message
I'm sending you the plans. You can use either the PI-12 or the LAB12 woofer in it, either will work just fine. We only carry the PI-12, but you can use either one in the three π subwoofer.
Our PI-12 woofer is essentially the same as LAB12, but machined to fit our cooling plug, used mostly in the 12π hornsub. That's the only difference, ours has the pole piece machined to a tighter tolerance.
Previous Topic: 3 pi plans
Next Topic: 2 pi questions
Current Time: Sat Oct 31 13:56:28 CDT 2026
