Home » Sponsored » Pi Speakers » V.C . Compresson driver
V.C . Compresson driver [message #53342] Sat, 28 March 2009 14:51 Go to next message
solomty is currently offline  solomty
Hy Wayne . I was looking several CD tweeters and some use a small vc 1.5 others 2 inch vc and other as the jbl 2446H with four in. vc .what do you recommend bigger vc ,1 inch exit or 2 inch exit. This voice coils size remember me of the very successful six inch Morel woofer with a whooping 3 in vc.
Re: V.C . Compresson driver [message #53343 is a reply to message #53342] Sat, 28 March 2009 19:41 Go to previous message
I use only 1" exit compression drivers, which typically have a 1.5" to 2" voice coil. All things being equal, bigger voice coils are better because they have greater thermal capacity. But all things aren't equal - bigger voice coils have greater mass and that kills top end extension - not something you want in a tweeter.
Previous Topic: 3pi with beyma cp380m
Next Topic: Active crossover for 3Pi
Current Time: Sun Sep 13 04:37:41 CDT 2026
