Home » Sponsored » Pi Speakers » Ciare ND 12.3 with modified Pi mid horn?
Ciare ND 12.3 with modified Pi mid horn? [message #53335] Wed, 25 March 2009 12:39 Go to next message
What would be the possibilty of successfully using the Ciare ND 12.3 midwoofer with a slightly modified Pi mid horn to acheive a bottom rolloff starting around 200Hz? And rolling them off up top around where the JBL 2226 is in the Four Pi at 1.3kHz?
Thanks for any input regarding this possibility, and Wayne for the Ciare measurements.
Norris
Ciare ND 12.3 measurements as follows:
RE = 6.1971 ohms
FS = 56.9656 Hz
QES = 0.2183
QMS = 10.0352
QTS = 0.2137
ZMAX = 291.0796 ohms
LE = 1.1372 mH
VAS = 58.9754 L
Diam = 261.9375 mm
Sd = 53887.1512
BL = 23.5536
Cms = 142.9669 um/N
Kms = 6994.625 N/m
Mms = 54.5984 g
Sens = 98.7321 db@1W/1m
Eff = 4.6925 %
Rms = 1.9474 ohms
Re: Ciare ND 12.3 with modified Pi mid horn? [message #53336 is a reply to message #53335] Wed, 25 March 2009 14:18 Go to previous message
If you get the driver, we can measure it on the horn. The bottom end can be modeled with Hornresp, but the upper end is largely determined by the way the cone behaves at HF. This cannot be simulated with a pistonic model, so we'll need measurements to see how it acts.
Previous Topic: 3-pi 4-pi question ?
Next Topic: New amp and old Theater 4 Pi -Blown Away!
Current Time: Sat Oct 31 19:54:50 CDT 2026
