Home » Sponsored » Pi Speakers » 6Pi - 7Pi bass cab same dimensions?
Re: Close, but not the same [message #53289 is a reply to message #53278] Wed, 04 March 2009 21:14 Go to previous messageGo to next message
Tracked down a hardware store that stocks 18mm 3 X 6 MDF.
Can order thicker than 10mm ply, but I was told there's no 'guarantee of quality' and 'would probably have voids'.
Baffle isn't so big, so there's probably no need for double thickness, true?
Re: Close, but not the same [message #53290 is a reply to message #53289] Wed, 04 March 2009 21:42 Go to previous message
Excellent! That will work very well.
The most important thing is bracing. Damping material placed as described in the plans is also very important. You can do a constrained layer, if you want. But I would consider that an option, whereas bracing and damping material as shown in the plans is mandatory.
Previous Topic: 7pi XO points
Next Topic: plans for Pi 4
Current Time: Sat Oct 24 21:00:22 CDT 2026
