Home » Sponsored » Pi Speakers » 6Pi - 7Pi bass cab same dimensions?
Oh, my mid-horn mkII idea [message #53281 is a reply to message #53278] Mon, 02 March 2009 17:05 Go to previous messageGo to previous message
PaulW is currently offline  PaulW
Child art added to give an idea of what I'm thinking of.
Indeed that was the context the mid-horn size got raised - and I never did use the edging method. But it was mentioned that the flare would benefit from being slightly bigger so, when I get round to remaking it I was going to increase the throat to corner distance by 1 inch with the top and bottom faces slightly curved to the middle with a 2 inch increase. The 'drum' holding the driver would be made from flexible MDF (MDF sheet with slots cut 2/3's the way through the thickness at regular intervals) formed over disc of ply. Well that's the plan, but then again, there's the power-amp upgrade, the preamp upgrade......
Paul
Previous Topic: 7pi XO points
Next Topic: plans for Pi 4
Current Time: Fri Nov 27 05:21:04 CST 2026
