Home » Sponsored » Pi Speakers » port
Re: port [message #53270 is a reply to message #53266] Sun, 01 March 2009 11:01 Go to previous message
Port length is 10", entry to exit. That dimension is shown on the baffle cutout drawing. Use the same material that you made the cabinet from. Thickness isn't really important, just make sure the inside dimensions are 3-1/2" x 6" and the total length from the front baffle edge where the port exits to the end inside the box is 10" long.
Previous Topic: Venturi Port ???
Next Topic: Mid-horn flatpack
Current Time: Sat Nov 07 07:08:47 CST 2026
