Home » Sponsored » Pi Speakers » Can you guess horn cut-off by dimension only?
Re: Can you guess horn cut-off by dimension only? [message #53252 is a reply to message #53248] Mon, 23 February 2009 12:30 Go to previous messageGo to previous message
Thanks Wayne,
So, for a JBL 2370A, they are claiming a cut-off of 630Hz with a depth (length) of ~7". So... 630Hs is a wavelength of 21.6",
so this horn is ~.31 of the wavelength at spec, right? Can I conclude that other horns with similar depths and dimensions
will have similar specs? I realize there's a *lot* of generalization in that statement.
90 x 40 dispersion
Full horn loading to 630 Hz
Dimensions: 6-7/8" H x 17-1/2" W x 6-7/8" D
Thx, Chris
Previous Topic: 4 Pi Plans
Next Topic: Why 7pi? 7pi and listening room considerations
Current Time: Tue Oct 20 19:32:50 CDT 2026
