Home » Sponsored » Pi Speakers » Delta 15 in 7 Pi?
Delta 15 in 7 Pi? [message #53237] Sun, 22 February 2009 13:34 Go to next message
jimbop is currently offline  jimbop
Wayne, I have Theater 4's with Eminence Delta 15 woofers. Can these be used in the 7-Pi? What midrange drivers should I use?
Jim D
Re: Delta 15 in 7 Pi? [message #53238 is a reply to message #53237] Sun, 22 February 2009 17:29 Go to previous messageGo to next message
Use the same midhorn, tweeter and crossover as the seven π cornerhorn but scale the bass bin larger, like the version for the JBL 2241, but tune it for 22Hz using a 4" long, 4" diameter port.
The link above describes the bass bin you should use, but remember to make the port longer, 4" diameter and 4" long.
Re: Delta 15 in 7 Pi? [message #53246 is a reply to message #53238] Sun, 22 February 2009 22:46 Go to previous messageGo to next message
Can you please send me the 7-Pi plans I need for this enclosure, including the midhorn plans?
Thanks!
Jim D
More questions [message #53247 is a reply to message #53238] Mon, 23 February 2009 10:55 Go to previous messageGo to next message
It seems that the bass bin for the Delta 15 is larger than the cabinet with other drivers. What are the differences in dimensions? Which drivers can be used in the smaller bass cabinet? (I probably cannot afford JBL drivers at this time.)
Also, what is the height and width of the midhorn?
I could not find the dimensions on your website.
Jim
Re: Delta 15 in 7 Pi? [message #53249 is a reply to message #53246] Mon, 23 February 2009 11:27 Go to previous messageGo to next message
Please send me your E-Mail address and I'd be happy to send you the plans.
Re: More questions [message #53250 is a reply to message #53247] Mon, 23 February 2009 11:31 Go to previous messageGo to next message
The seven π loudspeaker is designed to use the Eminence Omega 15 or JBL 2226. It can also use the JBL 2225 or 2205 woofers. The midhorn mouth is 24" x 12". You'll see that and all the answers to all your other questions in the plans.
Re: Delta 15 in 7 Pi? [message #53255 is a reply to message #53249] Mon, 23 February 2009 15:21 Go to previous messageGo to next message
jimmyjohn54@comcast.net
thanks
You've got mail! [message #53257 is a reply to message #53255] Mon, 23 February 2009 20:18 Go to previous message
Previous Topic: Why 7pi? 7pi and listening room considerations
Next Topic: Front port Vs Rear port
Current Time: Tue Oct 20 13:32:15 CDT 2026
