Home » Sponsored » Pi Speakers » Can you guess horn cut-off by dimension only?
Can you guess horn cut-off by dimension only? [message #53245] Sun, 22 February 2009 21:28 Go to next message
Wayne,
If all you know about a horn is it's dimensions, can you make a decent guess as to it's lower cut-off freq? I'm looking for some
bargin horns (Goldwood from PE) to cover 800Hz-5KHz. I picked up a pair of empty Cornwall cabinets and already have
everything except mid-horns to get them going.
Thx, Chris
Re: Can you guess horn cut-off by dimension only? [message #53248 is a reply to message #53245] Mon, 23 February 2009 11:17 Go to previous messageGo to next message
When horn length = 1/4λ, you can expect output to drop off rapidly under that frequency. The smoothness of response above that frequency, directivity, efficiency, etc. is determined by the rest of the horn's features.
Re: Can you guess horn cut-off by dimension only? [message #53252 is a reply to message #53248] Mon, 23 February 2009 12:30 Go to previous messageGo to next message
Thanks Wayne,
So, for a JBL 2370A, they are claiming a cut-off of 630Hz with a depth (length) of ~7". So... 630Hs is a wavelength of 21.6",
so this horn is ~.31 of the wavelength at spec, right? Can I conclude that other horns with similar depths and dimensions
will have similar specs? I realize there's a *lot* of generalization in that statement.
90 x 40 dispersion
Full horn loading to 630 Hz
Dimensions: 6-7/8" H x 17-1/2" W x 6-7/8" D
Thx, Chris
Re: Can you guess horn cut-off by dimension only? [message #53254 is a reply to message #53252] Mon, 23 February 2009 13:13 Go to previous message
1/3λ is a fairly safe cutoff frequency estimate. 1/4λ would be a drop dead value, one that I would not expect any acoustic loading below. 1/2λ is where efficiency gains are seen, with the highest efficiency range above that frequency. Between 1/4λ and 1/2λ, there are usually some ripples in response, sometimes mitigated by other horn features like flare profile and rear chamber size.
Previous Topic: 4 Pi Plans
Next Topic: Why 7pi? 7pi and listening room considerations
Current Time: Tue Oct 20 12:27:43 CDT 2026
