Home » Sponsored » Pi Speakers » Why 7pi? 7pi and listening room considerations
7pi and listening room considerations [message #53232 is a reply to message #53231] Thu, 19 February 2009 12:23 Go to previous messageGo to previous message
Panel absorbers are usually pretty effective for room damping. Should be great with seven π cornerhorns and your room layout looks good for them too.
The four π loudspeaker sounds wonderful, and doesn't lose much to the seven π when properly setup. However, if you have a suitable room, the seven π cornerhorns do sound better. They generate sound with uniform spectral balance throughout the entire room and it isn't just the top end of the spectrum, it's nearly the whole audio spectrum. The blend between midhorn and bass bin smoothes floor bounce and the higher modal frequencies too. In your room, I would expect the seven π cornerhorn to sound very nice.
http://www.pispeakers.com/photos/7Pi.jpg
seven π cornerhorn
Previous Topic: Can you guess horn cut-off by dimension only?
Next Topic: Delta 15 in 7 Pi?
Current Time: Sat Sep 05 12:02:50 CDT 2026
