Home » Sponsored » Pi Speakers » Seating
Seating [message #53160] Sat, 31 January 2009 18:37 Go to next message
Zene Gillette is currently offline  Zene Gillette
Wayne or ? ... I finally have my version of your PI 7's going. They are P.Audio 150 2226 woofers (already had) in a 4 cu. ft. box. Hoping to get the recommended JBL's from you soon. They are in corners of a 13 1/2' wall. C to C is 10'. Top section is horns on a lazy susan for adjusting angles +- 45 degrees. Back wall is 27' away and opens up to kitchen/dining room. It's relatively dead with bass traps, etc. Working on dispersing front. Equal triangle listening distance is 10' from speaker wall and max is 17' from speaker wall.
Would you give me some guidelines as to the best start for listening position and toe-in? I've always thought that horns are better listened to at a greater distance than the normal equal triangle position. With two variables; distance and mid horn angles experimenting would take forever. Zene
Re: Seating [message #53161 is a reply to message #53160] Sat, 31 January 2009 18:41 Go to previous messageGo to next message
Wayne .. Just found your response on imaging, etc. from early Jan. I will read. I'm sure my questions will be answered there. Zene
Re: Seating [message #53163 is a reply to message #53161] Sun, 01 February 2009 10:57 Go to previous message
The orientation shown at the link below is how these speakers were designed to be setup. This positioning method has been adopted by at least two other manufacturers that I know of. Try it, it really sounds good.
Previous Topic: Surrounds to complement 7pi and 4pi HT
Next Topic: Four Pi and BSC
Current Time: Thu Nov 05 03:29:14 CST 2026
