Home » Sponsored » Pi Speakers » Min Box size for 4Pi?
Min Box size for 4Pi? [message #53114] Wed, 21 January 2009 17:51 Go to next message
reguax is currently offline  reguax
Hi All
I just built my first 4Pi prototype and it looks bigger than i thought
I'm having serious WAF problems
I could try moving some furnitures and/or choosing a proper color/veneer for better integrating these 'refrigerators' (this is how my wife calls them! hehehe) into the room
Or I could try to make smaller boxes
Without changing components and keeping the standard crossovers, what would be the minimum box volume for getting a working 4Pi?
Omega Pro 15 works in boxes from 2 to 3.8 cu. ft.
Does it mean that I can do a 4Pi in a 2 cu. ft. box?
Will it sound close to the original?
Thanks!
Re: Min Box size for 4Pi? [message #53116 is a reply to message #53114] Wed, 21 January 2009 18:00 Go to previous messageGo to next message
Sorry, I wouldn't suggest any changes. The box is already a tight fit for the components it contains.
Re: Min Box size for 4Pi? [message #53118 is a reply to message #53116] Wed, 21 January 2009 18:42 Go to previous messageGo to next message
Well... Nothing more to say
I will follow the plans
After all, I'm the man... who cares about WAF!!!
Re: Min Box size for 4Pi? [message #53119 is a reply to message #53118] Wed, 21 January 2009 19:21 Go to previous message
Good Attitude! You'll love the speakers. If you finish 'em darker and put them in or close to corners, they don't look as big. Emphasize to your wife all the good snuggling and wine, chocolates, etc. you'll enjoy even more with better tunes.
Previous Topic: Countering throat distortion in conical mid horns
Next Topic: Alternate woofer for 3Pi
Current Time: Fri Nov 13 06:02:40 CST 2026
