Home » Sponsored » Pi Speakers » 4pi: floor mount or stand mount? / plans needed
4pi: floor mount or stand mount? / plans needed [message #53051] Tue, 06 January 2009 15:59 Go to previous message
Rocketmail is currently offline  Rocketmail
Hello,
New voice here. I am considering building a set of 4pi speakers, and wonder if they are intended to be used sitting directly on the floor, or could they be mounted on a low stand to raise the center of the 290 horn to ear level? I will be using them near corners (within a foot or so). Thanks.
Also, Wayne, if you would be kind enough to send me a set of 4pi plans, I would appreciate it. I will be using the 2226, DE250, and Eminence 290 setup with your crossovers.
Mark
Previous Topic: Subwoofer Recommended for 2 Pi Towers?
Next Topic: experience with compression drivers.
Current Time: Sun Nov 08 13:45:47 CST 2026
