Home » Sponsored » Pi Speakers » What solid filler for Theater 4 cabs...
Re: Altering dimensions [message #53005 is a reply to message #53004] Tue, 23 December 2008 12:16 Go to previous messageGo to previous message
jeff p is currently offline  jeff p
thanks, that helps.
looks like the main concern is floor bounce then.
i was thinking going close to 3.5 to 4 cubic ft. at 40hz...maybe 32"x17"x14" which i think would be approaching 3.5ft internal volume.
at that height the drivers would probably be 5-6" higher but spaced the same distance apart.
this is assuming the omega or the JBL would fit on a 17" baffle.
do you think there would be any noticeable effects to the midrange going to a 4ft enclosure if the driver spacing is kept the same and the drivers are no more than 6" higher than your plans for the pro cabinet.
Previous Topic: Seven- Pi vs Eight- Pi ?
Next Topic: JBL 2446 & 2226 in a Corner Horn Design
Current Time: Fri Sep 04 11:13:37 CDT 2026
