Home » Sponsored » Pi Speakers » Back loaded corner horn
Re: Back loaded corner horn [message #52967 is a reply to message #52961] Mon, 15 December 2008 15:01 Go to previous messageGo to previous message
xsheaffer is currently offline  xsheaffer
Wayne,
I remember in one of your tutorial papers (which I cannot seem to locate...GRRRRR), there was a factor used to calculate the spacing from the wall that I don't understand. IIRC it used a quantity "V" times sqrt 3, but I don't recall. Old age I guess...
The back loaded 1 driver approach is a little different than your Pi implementation, but I want to employ the same approach using a coupling chamber for the backwave of the one driver. The trouble is I don't have a very good understanding of the design parameters of the Pi corner horn! I am just getting started.
Wayne, could you steer me toward more info? Much appreciated any help you could provide!
Thanks!
Previous Topic: Four Pi ,Omega 15 vs JBL 2226h ?
Next Topic: jbl 2205 vs eminence omega 15
Current Time: Mon Oct 19 21:46:08 CDT 2026
