Home » Sponsored » Pi Speakers » Help with 4Pi box (newbie questions)
Re:Some pix [message #52941 is a reply to message #52935] Wed, 10 December 2008 21:28 Go to previous messageGo to previous message
The port is just a 4 sided box, open at both ends.
Have your friend make it to exact size but the cut-out in the baffle a litle smaller so after it's glued on he can use a flush trim bit to make the baffle cut-out neatly flush with the port.
The brace in the second pic is not a substitute for 1x4 or 2x4 pieces glued directly to the inside of the cabinet, then cross-braced. It helps with bracing but moreso with getting the box perfectly square during glue-up.
Previous Topic: What Thickness Baltic Birch To Order For 2 Pi Floorstanding
Next Topic: higher cut-off for 7pi
Current Time: Thu Oct 29 05:22:28 CDT 2026
