| EV SP15B in Pi 4 ??? [message #52899] |
Tue, 25 November 2008 15:49  |
James
Messages: 23 Registered: May 2009
Chancellor |
I've got a pair of these in mint condition, but I can't find complete T/S numbers. I'd really like to try them in a Pi 4 -style arrangement. Does anybody know where I might dig up detailed data on these? The Electro-vice site is no help -- not enough info. Thanks in advance!
| Re: EV SP15B in Pi 4 ??? [message #52900 is a reply to message #52899] |
Tue, 25 November 2008 17:53   |
Messages: 19102 Registered: January 2001
According to ThieleSmall.com, the EVM 15B specs are as follows:Brand Electro Voice Model EVM-15B Description Range / type Woofer Typical use PA Recomended enclosure Series Pro-Line Manufacturer Order nr Production status Discontinued Nom. diamerer [inch] 15 Vas [Liters] 260 Qts 0,3 Qes 0,31 Qms 13 Fs [Hz] 43 Sensitivity [dB] 101 Max Power [W] 400 Power definition continous Lower freq [Hz] 60 Upper freq [Hz] 3500 Rec. Filter freq [Hz] xmax [mm] 3,25 Moving mass [g] 48 Disp area [m2] 0,086 Disp Vol [cm3] xdamage [mm] 12,5 Air gap [mm] Coil height [mm] Coil diameter [mm] 62,5 Cms [mm/N] 0,214 Rms [N*s/m] 1,4 Magnet weight [gr] 2,225 Magnet height [mm] Magnet diameter [mm] Magnet material - Re [ohm] 5,2 Z [ohm] 8 L [mH] 0,5 Bl [Tm] 17,5 Magnetic flux [Wb] Flux density [T] Outer diam. [mm] Bolt circle [mm] Nr of bolts [Nr] Cutout [mm] Weight [Kg] 9,08 Height [mm] Depth [mm] Driver volume [Liters] Frequency SPL / Z Home page [URL] http://www.electrovoice.com Data sheet [URL} Enterd by - Date reviewed 2003-11-09 Date added 2003-11-09
| Re: EV SP15B in Pi 4 ??? [message #52901 is a reply to message #52900] |
Tue, 25 November 2008 19:12   |
James
Chancellor |
Hi Wayne, The EVM series and the SP series aren't the same. The SP-15B is a smaller magnet version of the SP-15, both of which were originally designed for hi-fi use (complete with whizzer cone). They are lower Fs, higher Qts, and lower sensitivity than the EVM's. The Electrovoice website does give a suggested box/vent size, but I'd sure like to find the detailed T/S numbers and see what a Pi-aligned enclosure would look like. Thanks very much for the info, and your effort. The search continues ... James
| Re: EV SP15B in Pi 4 ??? [message #52905 is a reply to message #52903] |
Wed, 26 November 2008 22:32   |
James
Chancellor |
Wow, what a great resource -- thanks for the link! I'm probably wrong, but the limited literature I've been able to find on the EV SP-15B indicates that it's closer to the SP-15, both with whizzer cones, ceramic mags, stamped-steel baskets, and intended for hi-fi use. The SP-15 even had a midrange/treble control. The SP-15A has a cast basket, and an Alnico mag (I think). You may well be right that there is little difference among them, but in one piece of EV lit I found regarding the SP-15B, it was suggested that it's best use was in an infinite baffle. If I understand that application correctly, which I probably don't, then it might be that the SP-15B has a much higher Qts, making it a very different animal. I think I'm going to get that woofer tester from PE. Thanks again for the link ... I found info on several other speakers I was having trouble finding. Happy Thanksgiving to all! Best, Jim
| Re: EV SP15B in Pi 4 ??? [message #52909 is a reply to message #52905] |
Thu, 27 November 2008 11:07  |
Bill Wassilak
Messages: 402 Registered: May 2009
Illuminati (1st Degree) |
Yes it would be best to get the woofer tester. Also speakers with a higher Qts should go into an infinite baffle, either that or they'll need a larger bass reflex type cabinet of some sort. Happy Thanksgiving! Bill
