Home » Sponsored » Pi Speakers » 2 Pi Tower Build Tips
Re: 2 Pi Tower Build Tips [message #52863 is a reply to message #52860] Thu, 13 November 2008 00:46 Go to previous messageGo to previous message
I always make the cabinets with all sides glued together and I gain access through the woofer holes. The only exception is horns where that would be impossible. Those have access panels.
Bracing should be done as two cross-braces, one-third the way up and one-third the way down. Of course, you can never over brace. Additional braces like Shane did and/or window braces like Bill suggests won't hurt. Some even use a constrained layer to damp the box or glue random blocks or panels on the baffle interiors to break up panel resonances. There comes a point of diminishing returns, but the minimum should be a pair of cross-braces.
Use R11 or R13 insulation and span one side, the top and the front baffle, up to the woofer cutout hole. Also attach a sheet to each brace that completely spans the cross-section. It will look like you've broken the cabinet into three sections. Bass will go right through the insulation but it will trap midrange frequencies up, which is just exactly what we want.
The amplifier connection panel is included with the kit. It requires a 2-7/8" x 2-1/4" cutout on the back in a convenient place. The crossover is wired into the cable assemblies, so you can "plug and play" when you get them. The crossover components aren't so heavy that they can't just hang off the drivers, but you could also wire tie them to a cross-brace or attach them to a panel with silicon adhesive.
Previous Topic: lab 12 port freq. ???
Next Topic: Back to the Aikido
Current Time: Fri Nov 27 08:42:46 CST 2026
