Home » Sponsored » Pi Speakers » "Bill Epstein" cabinet building details?
Re: "Bill Epstein" cabinet building details? [message #52842 is a reply to message #52841] Sat, 01 November 2008 20:51 Go to previous messageGo to previous message
Hi Bill,
Thanks for your reply.
This Arauco sounds interesting, what is the thickness and dimensions of this plywood?
Does it have voids, and a rough C grade finish. Or, is it voidless with a B grade finish, smooth for veneering?
I have been thinking about using some 1/8" oak flitches that were cut from a 13" wide board as side and back cover for these boxes. then use a darker veneer for the front baffle for contrast.
Certainly a box built of this Arauco if 3/4" thick, where I could butt all of the joints, would simplify life and make for a substantial box.
Your box design sounds like a good direction with the proper bracing.
I would think the window frame braces are made from the marine plywood? Did you laminated layers of this plywwod for the bace, or is it a single layer?
Did you use any special glue when gluing up the butt joints?
Any other specific information will be helpful to this carpentry newbie.
Norris
Previous Topic: 3pi/4pi plans? Horn lens question
Next Topic: Pi 3 plans please?
Current Time: Fri Oct 16 07:36:20 CDT 2026
