Home » Sponsored » Pi Speakers » how loud will 2 watts get?
Re: how loud will 2 watts get? [message #52763 is a reply to message #52761] Wed, 15 October 2008 21:55 Go to previous messageGo to previous message
The BH pre-amp ghas 10db gain which is a nice number and will appreciably raise the gain you can have from 2 watts.
How loud will 2 watts play? I easily get average 85dB and peaks of 95 with my 1.8 watt amp and 4 Pi Pros w/o a pre-amp. 12x18 room. There is lttle 'headroom', of course, i.e., rock bands will play loud but full orchestras will stress and clip the amp.
The 2 Pis have a lot of 'apparent' bass so I wouldn't worry about that. They're also a bit on the warm side with less detail than you get with better drivers. This makes them a good candidate for one of the inexpensive chip amps, at least until your experience grows.
I personally think the ST-70 is waaay over-rated. Depending on your budget, the Audio Note Kits 6550 amp would be great or build the JE Labs 300B, schematics and pix of the wiring are everywhere. I'm not familiar with the Decware or BH Sex amp.
I built one of these a few years ago and it blew away an ST-70 I had at the same time: Ella on Audiogon
Previous Topic: Pi 3 plans please?
Next Topic: lab 12 port freq. ???
Current Time: Fri Oct 16 08:44:00 CDT 2026
