Home » Sponsored » Pi Speakers » Adding DE250 to 4 Pi?
Adding DE250 to 4 Pi? [message #52710] Tue, 07 October 2008 10:24 Go to next message
GarlandGarland is currently offline  GarlandGarland
Wayne or others,
I've updated the crossover and love the sound. Now I've purchased a pair of B&C DE250 drivers to go in. Am I right to assume that I hook them up as in the crossover schematic, with the black post to wire 1+ and the red to 1- and the woofer red to 2+ and black to 2-? Are the two drivers out of phase?
Just want to make sure I hook em up right the first time!
Thanks,
Garland
Re: Adding DE250 to 4 Pi? [message #52711 is a reply to message #52710] Tue, 07 October 2008 11:57 Go to previous messageGo to next message
B&C's are like many JBL's- the black is forward motion with pos. signal, opposite of most other speakers. I put a B&C in one side of mine to a/b them, and the result clear to all who listened.
Re: Adding DE250 to 4 Pi? [message #52712 is a reply to message #52710] Tue, 07 October 2008 12:03 Go to previous messageGo to next message
Connect the drivers as shown in the schematic. Also, be sure to change R1 and R2, because voltage sensitivity of the DE250 is a little higher than the PSD2002.
Re: Adding DE250 to 4 Pi? [message #52714 is a reply to message #52712] Tue, 07 October 2008 15:10 Go to previous messageGo to next message
Hi Wayne,
I may be confused but note 6 in the crossover schematic calls for R1a, b, c and d to be changed but does not mention the R2 chain being changed. Is there an error?
G.
Re: Adding DE250 to 4 Pi? [message #52715 is a reply to message #52714] Tue, 07 October 2008 15:54 Go to previous message
You're not confused, you're right. I tend to think of R1/R2 as a pair but in this case, the value of R2 remains the same. Here's a chart of R1/R2 values at various padding levels:
Previous Topic: 4 pi plans
Next Topic: Recommended toe in
Current Time: Tue Oct 20 07:54:34 CDT 2026
