Home » Sponsored » Pi Speakers » Woofer for Econowave
605A [message #52556 is a reply to message #52553] Sat, 30 August 2008 10:47 Go to previous messageGo to previous message
ecc83 is currently offline  ecc83
Hello Wayne,
maybe you have a suggestion for a PI aligned enclosure for the Altec 605A?
fs: 30.3 Hz
Re: 9.3 ohm
Qts: .25
Qms: 3.01
Qes: .27
Vas: 14.33 cu ft
Xmax: 0.15 inch
What crossover would you suggest?
Best regards
Frank
Previous Topic: HF bypass cap for active crossovers/EQ
Next Topic: I will check the cables first...I will check the cables first...I will check the cables first...
Current Time: Sat Oct 17 10:52:56 CDT 2026
