Home » Sponsored » Pi Speakers » Woofer for Econowave
Re: Woofer for Econowave [message #52551 is a reply to message #52550] Fri, 29 August 2008 11:52 Go to previous messageGo to previous message
I like the Alpha 10, but a driver this small makes the crossover point higher for directivity matching in the horizontal plane. This in turn reduces the angle of the vertical nulls. If the Alpha 10 is used on a horn, the horn sets the pattern but as a direct radiator, the size of the cone is what matters. When matching a direct radiator to a horn, I prefer 12" and 15" drivers. Everything seems to come together in this configuration.
When using the Delta 12LFA, I recommend you use the three π crossover and the physical spacing shown in the plans. The guys over on AK have made their crossover circuit use the same basic layout, so it's definitely on the right track. But I'm not sure they've tested it as thoroughly, particularly in regards to baffle placement, phase and null angles. I think the Econowave and its variants are all very much still evolving. The three π is not, it is a tested and mature design.
Previous Topic: HF bypass cap for active crossovers/EQ
Next Topic: I will check the cables first...I will check the cables first...I will check the cables first...
Current Time: Sat Oct 17 10:53:06 CDT 2026
