Home » Sponsored » Pi Speakers » Woofer for Econowave
Re: Woofer for Econowave [message #52550 is a reply to message #52549] Fri, 29 August 2008 08:23 Go to previous messageGo to previous message
ecc83 is currently offline  ecc83
Thank you very much for your advice!
As i understand you are not a friend of the alpha10/econowave combo.
I think the 3pi (with the delta 12lf)would be a good choice for me.
-Can i go with the puplished econowave crossover?
http://audiokarma.org/forums/attachment.php?attachmentid=90113&d=1210028233
-Can you send me the 3pi plan?
Best regards
Frank
Previous Topic: HF bypass cap for active crossovers/EQ
Next Topic: I will check the cables first...I will check the cables first...I will check the cables first...
Current Time: Sat Oct 17 10:52:53 CDT 2026
