Home » Sponsored » Pi Speakers » HF bypass cap for active crossovers/EQ
HF bypass cap for active crossovers/EQ [message #52541] Tue, 26 August 2008 23:05 Go to next message
Wayne,
For active crossovers and EQ, does it make sense to set the graphic EQ such that there is 6dB boost at 20KHz relative to 10KHz?
That would at least match the slope of your passive crossover component. I'll have to check that against what I have set up already.
Is 10KHz where the bypass cap kicks in?
Thx, Chris
Tweeter horn compensation [message #52542 is a reply to message #52541] Tue, 26 August 2008 23:49 Go to previous messageGo to next message
The response graph you want for the tweeter circuit looks like the chart shown below. It is the conjugate of the HF driver's power response.
Re: Tweeter horn compensation [message #52545 is a reply to message #52542] Wed, 27 August 2008 12:47 Go to previous messageGo to next message
Hi Wayne,
So I got the slope right, but starting point off an octave. So, that's 12dB of delta. Seems like a lot, but it does seem to
sound right. The end goal is to get a flat measured acoustic response, right?
Thx, (wish I could be done tweaking, but not in my nature) Chris
Re: Tweeter horn compensation [message #52547 is a reply to message #52545] Wed, 27 August 2008 21:42 Go to previous message
Yes siree, the goal is flat acoustic response, on-axis and off-axis within the coverage pattern.
Previous Topic: 2- PI
Next Topic: Woofer for Econowave
Current Time: Sat Oct 17 08:33:22 CDT 2026
