Home » Sponsored » Pi Speakers » 20uF Cap for 4Pi Cross Over
20uF Cap for 4Pi Cross Over [message #52503] Tue, 19 August 2008 19:35 Go to next message
Norbert is currently offline  Norbert
I'm trying to source the 20uF film caps but don't see much selection out there that don't cost an arm and leg.
Aside from Dayton (PartExpress), Clarity (E-Speakers), Solen, or motor run is there any other ones I should be looking?
Thanks,
Norbert
Re: 20uF Cap for 4Pi Cross Over [message #52504 is a reply to message #52503] Tue, 19 August 2008 20:12 Go to previous messageGo to next message
The poly caps from those manufacturers all sound very good, as do Erse. As you say, there are some high end caps that sound nice also, but at 10x the price. The Daytons, Solens and Erse caps are great sounding for the money.
Re: 20uF Cap for 4Pi Cross Over [message #52507 is a reply to message #52503] Tue, 19 August 2008 21:48 Go to previous messageGo to next message
the Obligato basic cap from diyhifi in Hong Kong cost under $10 in that size, and will rival an Auricap.
Re: 20uF Cap for 4Pi Cross Over [message #52509 is a reply to message #52507] Tue, 19 August 2008 22:23 Go to previous messageGo to next message
Hi Matt,
The Obligato's from http://www.diyhifisupply.com only comes in 22uF I am trying to stick closer to 20uF as per Wayne's suggestion from previous post. I guess technically it is within the design's tolerance.
Thanks.
Re: 20uF Cap for 4Pi Cross Over [message #52510 is a reply to message #52509] Tue, 19 August 2008 22:34 Go to previous messageGo to next message
I'm using the 22uF Obbligato right now but also tried the 20uF Aerovox motor run caps. Very little difference, if any.
Re: 20uF Cap for 4Pi Cross Over [message #52512 is a reply to message #52509] Tue, 19 August 2008 22:39 Go to previous messageGo to next message
get two tens in parallel? I've used 2 tens and a 1.5 before, North Creeks, with no probs. I replaced them with the big Obligatos.
Re: 20uF Cap for 4Pi Cross Over [message #52514 is a reply to message #52510] Wed, 20 August 2008 00:18 Go to previous message
motor runs may be the way to go. A friend of a friend is in the heating repair business and he is collecting used motor run caps for me.
Thanks.
Previous Topic: H-290: flush vs. surface mount?
Next Topic: S/Hand JBL 2226's in need of a re-cone
Current Time: Sat Oct 17 01:55:45 CDT 2026
