Home » Sponsored » Pi Speakers » H-290: flush vs. surface mount?
H-290: flush vs. surface mount? [message #52497] Tue, 19 August 2008 09:01 Go to next message
I'm pondering whether or not to rebate the horn, whether the improved aesthetics are worth the trouble invloved. Making a template, hand-carving the four radii, and beefing up the baffle thickness will be almost as much work as the whole rest of the project.
What say you?
Re: H-290: flush vs. surface mount? [message #52498 is a reply to message #52497] Tue, 19 August 2008 11:18 Go to previous messageGo to next message
I like the looks of recessed mounting, but I don't buy into the idea of improved acoustics. The edge is much too thin to matter, in my opinion. So the improvement is purely aesthetic.
Re: H-290: flush vs. surface mount? [message #52499 is a reply to message #52498] Tue, 19 August 2008 11:51 Go to previous messageGo to next message
How was the subject here done, flush or surface mount?
Re: H-290: flush vs. surface mount? [message #52500 is a reply to message #52499] Tue, 19 August 2008 12:12 Go to previous messageGo to next message
I don't remember for sure, but I'm almost positive those were surface mounted.
Re: H-290: flush vs. surface mount? [message #52502 is a reply to message #52500] Tue, 19 August 2008 18:43 Go to previous messageGo to next message
Is that cabinet made out of Oak Plywood ??? THANKS
Re: H-290: flush vs. surface mount? [message #52505 is a reply to message #52502] Tue, 19 August 2008 20:15 Go to previous message
No, it was veneered MDF as I recall.
Previous Topic: cone midhorn vs compression mid sound
Next Topic: 20uF Cap for 4Pi Cross Over
Current Time: Sat Oct 17 04:59:07 CDT 2026
