Home » Sponsored » Pi Speakers » 1-PI x-over???
1-PI x-over??? [message #52333] Thu, 17 July 2008 19:52 Go to next message
how much spl does the 10 ohm resistor knock off ? like 2 db ? Thanks!!!
Re: 1-PI x-over??? [message #52334 is a reply to message #52333] Thu, 17 July 2008 22:47 Go to previous messageGo to next message
There is no 10Ω resistor in the one π loudspeaker. There is a 16Ω resistor, but it's in parallel with the tweeter so it doesn't attenuate it. The shunt resistor provides a little bit extra damping, and works sort of like a Zobel. The tweeter has a 12Ω impedance peak at 650Hz and this resistor reduces that peak. Without it, more low frequency energy than wanted would be developed across the tweeter.
Re: 1-PI x-over??? [message #52337 is a reply to message #52334] Fri, 18 July 2008 03:29 Go to previous messageGo to next message
OK ,its a 16 ohm thats what the diagram said but it had a 5 uf. capacitor and we are supposed to use a 10uf ,is that correct? Thanks.
Re: 1-PI x-over??? [message #52341 is a reply to message #52337] Fri, 18 July 2008 12:36 Go to previous message
The crossover capacitor used in the one π and two π loudspeakers is 10uF, that's right. I made a prototype with a different tweeter having 8Ω average impedance, and I think I may have inadvertently sent that schematic out for a while. If you got the wrong schematic, I apologize. The crossover for the DX25 has a series 10uF capacitor followed by a 16Ω shunt resistor.
Previous Topic: 2226 Box size questions, or, where're my ears?
Next Topic: I couldn't help myself
Current Time: Sat Nov 07 03:34:23 CST 2026
