Home » Sponsored » Pi Speakers » 7 Pi bass cabinet
Re: 7 Pi bass cabinet [message #52246 is a reply to message #52245] Wed, 25 June 2008 19:29 Go to previous messageGo to previous message
PaulW is currently offline  PaulW
Hi Matts, I use the 4 ohm tap (in preference to the 8) as although this provides a slightly less open sound and reduced output, overall the bass is better controlled and the tendency for the upper frequency shout is reduced. I'd hope the MagneQuest iron did provide a significant upgrade as the output transformer supplied as standard costs under $5! I'm also running the HF compression horn with a small (thin) amount of wadding placed in the throat to further tame the hard edge I'm hearing - hopefully this will tone down a bit over time and I can remove the wadding. But may also be an indication of upper frequency 'room effects'.
Paul
Previous Topic: Wayne, can I have the plans for the seven pi 18?
Next Topic: 4 pi x-over with Kappa pro 15lfa
Current Time: Sat Nov 07 17:43:14 CST 2026
