Home » Sponsored » Pi Speakers » lab12
lab12 [message #52222] Tue, 17 June 2008 22:33 Go to next message
David Morehouse is currently offline  David Morehouse
A Lab12 in a ported box of 3.6 cu.ft. 1-3" port,length 7.48" mach.16
1-6" port,length 34.29" mach.04
Is mach .16 ok? What would be gained or lost by externally mounting a 6" port? excluding saf.
Excursion and vent airspeed [message #52223 is a reply to message #52222] Wed, 18 June 2008 12:28 Go to previous message
Most prefer to keep airspeed under 75mph, and the airspeed you've calculated is 125mph. Remember, however, that maximum airspeed is only realized at frequencies near fb, and only at high power. You can use a steep high-pass filter to reduce excursion below cutoff if necessary, but for home theater and hifi subwoofer applications, I don't think you'll need it, either for port "chuffing" or for protection against over-excursion. You can also reduce turbulence using ports with radiused ends.
Previous Topic: Since no one asked...(long)
Next Topic: Pi 7 thread on HiFi WigWam
Current Time: Fri Oct 16 23:00:26 CDT 2026
