Home » Sponsored » Pi Speakers » Dome tweeter with JBL 2226J?
Synergy [message #52186 is a reply to message #52184] Sun, 08 June 2008 13:15 Go to previous message
How about trying the Morel tweeter by swapping out the DX-25 in a one π or two π speaker? I think those would be better uses for the Morel tweeter and I'll bet they would sound good. If you can find an old JBL 2115 woofer on eBay, it's an excellent woofer for a speaker like that. Another good woofer option would be the Fostex F200A.
In the four π loudspeaker, the horn tweeter directivity is matched to the midwoofer in the crossover range. This allows a smooth transition not only on-axis but off-axis as well. Plus, the sensitivity of the woofer is just right for matching the tweeter's passive EQ scheme. You need about 10dB to provide conjugate compensation of the power response curve, and that's the amount of difference between woofer and tweeter, so it's a perfect match. There's synergy in that combination.
Previous Topic: Pi4
Next Topic: Plans 4 PI
Current Time: Thu Nov 19 16:09:53 CST 2026
