Home » Sponsored » Pi Speakers » 7 Pi bass cabinet
7 Pi bass cabinet [message #52167] Sun, 25 May 2008 22:36 Go to next message
PaulW is currently offline  PaulW
Hi Wayne, I'm just cutting out the sections for my bass cabinets and thinking about changing the style of the rear section - the 'pointy' bit. To soften their looks a bit I was wondering if I could radius the angles instead of having them sharp? This would also mean the rear panels on the apex couldn't run the full width (12 3/8") but would be reduced to about 7" in the middle of the angled part. Would there be any sonic changes in having a wide gap at the apex (rear where it faces the wall) of the cabinet and not having the panels going fully to the outer edges? I hope that makes some sense?
Paul W
Re: 7 Pi bass cabinet [message #52168 is a reply to message #52167] Mon, 26 May 2008 12:35 Go to previous messageGo to next message
Can you draw it up and post or send it to me? I'm not visualizing your idea.
The main thing is the cabinet that loads the woofer. The rest of the cabinet is essentially a positioning device.
Re: 7 Pi bass cabinet [message #52169 is a reply to message #52168] Tue, 27 May 2008 05:39 Go to previous messageGo to next message
I think you answered the question really, but I'll do a quick sketch later and post it for you comments anyway.
Thanks.
Paul
Re: 7 Pi bass cabinet sketch [message #52170 is a reply to message #52169] Tue, 27 May 2008 14:41 Go to previous messageGo to next message
Sorry about the childish quality, but hopefully you can see what I mean now?
Paul
Re: 7 Pi bass cabinet sketch [message #52171 is a reply to message #52170] Tue, 27 May 2008 16:34 Go to previous messageGo to next message
Oh, yes, very good. That's actually a very good sketch. What you're doing will work just fine.
and this is how the really look [message #52181 is a reply to message #52171] Sat, 07 June 2008 12:25 Go to previous messageGo to next message
Nearly at the end of the build
Re: and this is how the really look [message #52182 is a reply to message #52181] Sat, 07 June 2008 18:53 Go to previous messageGo to next message
Looks nice ,Where did you get the plywood ???
Re: and this is how the really look [message #52183 is a reply to message #52182] Sat, 07 June 2008 19:16 Go to previous messageGo to next message
Local B&Q DIY store - I'm based in the UK
Paul W
Re: and this is how the really look [message #52187 is a reply to message #52183] Sun, 08 June 2008 13:18 Go to previous messageGo to next message
Looks great! Please keep us posted on your progress!
Will do...... [message #52188 is a reply to message #52187] Sun, 08 June 2008 19:06 Go to previous messageGo to previous message
Although the next post should be a picture of them up and running, only a few little bits and pieces to do now.
1st set of 7 Pi's in the UK?
Paul
Previous Topic: Wayne, can I have the plans for the seven pi 18?
Next Topic: 4 pi x-over with Kappa pro 15lfa
Current Time: Mon Nov 16 04:36:33 CST 2026
