Home » Sponsored » Pi Speakers » Pi Theater Four and B&C compression drivers
Pi Theater Four and B&C compression drivers [message #52106] Sat, 10 May 2008 04:59 Go to next message
peppennino is currently offline  peppennino
Hi Wayne! I have the intention to switch to B&C DE250 on my Th4 and use the PSD 2002 for rear channel speakers. In that speaker, wich are the most important differences between the Eminence and B&C drivers? What I have to change on Xovers?
Many thanks in advance,
Vincenzo
Re: Pi Theater Four and B&C compression drivers [message #52107 is a reply to message #52106] Sat, 10 May 2008 11:21 Go to previous messageGo to next message
The DE250 is a little smoother and a little louder. The crossover is a little different as a result. You'll need to change the value of R1 from 16Ω to 25Ω.
Re: Pi Theater Four and B&C compression drivers [message #52108 is a reply to message #52107] Sun, 11 May 2008 04:38 Go to previous messageGo to next message
Many thanks, Wayne! What about F.R. with the Eminence horn? Is it more extended on the top?
Re: Pi Theater Four and B&C compression drivers [message #52109 is a reply to message #52108] Mon, 12 May 2008 13:06 Go to previous messageGo to next message
There is a little bit more on the top end and it's a little smoother too. As you can see from the response curve below, the PSD2002 has +/- 2dB ripple and the DE250 is more like +/- 1.5dB. The signal is unequalized, so don't be concerned by the overall falling response. This is normal for a compression driver and is easy to compensate in the crossover.
Re: Pi Theater Four and B&C compression drivers [message #52110 is a reply to message #52109] Tue, 13 May 2008 12:13 Go to previous message
Many thanks, Wayne! very interesting response, mostly for the 8-9K region..
Thanks again!
Vincenzo
Previous Topic: Circuit Protection
Next Topic: Gov. Stimulis rebate works!
Current Time: Wed Nov 18 00:48:34 CST 2026
