Home » Sponsored » Pi Speakers » Circuit Protection
Circuit Protection [message #52097] Sun, 04 May 2008 17:24 Go to next message
What size (ballpark) amps require the use of circuit protection- i.e. the light bulbs- for the compression driver? I didn't use them in my Pi4's driven by 2A3's, haha, but am making a pair for a friend who uses SS. Am using B&C 250's and 2226's.
Re: Circuit Protection [message #52098 is a reply to message #52097] Sun, 04 May 2008 23:59 Go to previous messageGo to next message
Solder a couple of 211-2 automotive bulbs in parallel, and put them in series with the tweeter circuit, ahead of capacitor C2. That will act as a limiter, because the bulbs will start to glow at high power, which will increase series resistance.
Re: Circuit Protection [message #52099 is a reply to message #52098] Mon, 05 May 2008 00:49 Go to previous messageGo to next message
Wayne, at what size amp would you think these are necessary? Thx.
Re: Circuit Protection [message #52100 is a reply to message #52099] Mon, 05 May 2008 01:31 Go to previous messageGo to next message
I can't see having any worries below 400 watts. If you put half that much power into the tweeter as a pure sine wave within its passband, that would smoke it but the energy distribution is way down at tweeter frequencies for music, voice, etc. For that reason, the bulbs don't light up until you're really pushing the power.
Re: Circuit Protection [message #52101 is a reply to message #52100] Mon, 05 May 2008 01:37 Go to previous message
thanks, Wayne. I'll find out about his amps- some kind of large Adcom, but I'm not sure how large.
Previous Topic: pi6 crossover
Next Topic: Pi Theater Four and B&C compression drivers
Current Time: Fri Nov 06 04:56:26 CST 2026
