Home » Sponsored » Pi Speakers » Question about 2 Pi Towers and Tweeter Options
Question about 2 Pi Towers and Tweeter Options [message #52012] Wed, 16 April 2008 07:51 Go to next message
crazychile is currently offline  crazychile
I just received the plans for 2 Pi Towers (Thanks Wayne) and was looking at the ordering options. Is the Vifa Tweeter upgrade meant for old existing Pi one and two speakers, or is it an upgrade for both the old and the new?
I guess what I'm asking is do I need to spend another $30 per speaker on the 2 pi kits to get the Vifa tweeter? If so, what are the current stock soft domes that come with the kit?
Thanks,
crazychile
Re: Question about 2 Pi Towers and Tweeter Options [message #52019 is a reply to message #52012] Wed, 16 April 2008 12:23 Go to previous messageGo to next message
The Vifa DX25 comes with the kits these days. I added the upgrade option so people with earlier model speakers could upgrade them. If you buy a two π tower kit, you get the Vifa DX25 tweeter, the Alpha 10 woofer and crossover included. No upgrade needed.
Re: Question about 2 Pi Towers and Tweeter Options [message #52021 is a reply to message #52019] Wed, 16 April 2008 22:20 Go to previous messageGo to next message
Thanks Wayne. One more stupid question.
On the Xover plans you sent me it says use a 4.7uf cap. On the tweeter upgrade it says it comes with a 10uf cap. Which is right?
Thanks,
crazychile
Re: Question about 2 Pi Towers and Tweeter Options [message #52027 is a reply to message #52021] Thu, 17 April 2008 10:28 Go to previous message
The crossover should use a 10uF capacitor.
Previous Topic: 4 pi, x-over
Next Topic: Three pi crossover
Current Time: Thu Oct 29 22:58:46 CDT 2026
