Home » Sponsored » Pi Speakers » 7pi crossover plans
Re: You've got mail! [message #51996 is a reply to message #51995] Thu, 10 April 2008 13:14 Go to previous messageGo to previous message
DICK is currently offline  DICK
Yes sir I did that and then I could print it thankyou. Now I got a question about the crossover. Since I'm using a 2226 in a bass bin to the midrange horn, am I following the schematic for the 4pi up to the woofer, then pick up from there with the schematic for the 7pi midhorn & tweeter? Also I'm a little vague with the tweeter since I'm using the b&c 250. Will R1 & R2 require higher ohm's? And what mH would L2 need. And is the tweeter's polarity normal or reversed? You bet-cha I'm cornfused. Thanks Wayne.
Rick
Previous Topic: Mid-horn flare; how critical are the dimensions?
Next Topic: 2pi crossover and box plan
Current Time: Fri Nov 06 20:58:00 CST 2026
