Home » Sponsored » Pi Speakers » Pi 4 speakers questions
Pi 4 speakers questions [message #51906] Wed, 12 March 2008 05:37 Go to next message
Robert is currently offline  Robert
What is the different between Pi4 and theater4?
I'm using a 5w tube amp and my room is approx: 5m by 6m
Which speakers is more suitable for my room?
Re: Pi 4 speakers questions [message #51908 is a reply to message #51906] Wed, 12 March 2008 11:18 Go to previous messageGo to next message
The Theater Series four π used an Eminence Delta 15 in an 8ft 3 cabinet. I've condensed the line down to just one version of each model, and the one listed is the one that used to be called the Professional Series four π, containing a JBL 2226 in a 3ft3 cabinet. An Eminence Omega 15 can also be used in this model.
Re: Pi 4 speakers questions [message #51909 is a reply to message #51908] Thu, 13 March 2008 01:19 Go to previous messageGo to next message
Thanks for your reply Wayne.
Due to budget constraint I'm thinking of using Eminence Delta15 and B&C DE250 for now and will be upgrading to Omega15 or JBL driver in the future.
Which cabinet(Pi4 or Theater4) gives the flexibility of using all the three divers?
Re: Pi 4 speakers questions [message #51911 is a reply to message #51909] Thu, 13 March 2008 11:38 Go to previous messageGo to next message
No cabinet supports a swap between a Delta 15 and an Omega 15 or JBL 2226. They're very different woofers. You can swap a JBL 2226 for an Omega 15, but not for a Delta 15.
Re: Pi 4 speakers questions [message #51914 is a reply to message #51911] Fri, 14 March 2008 02:32 Go to previous messageGo to next message
Thanks again for you reply, Wanye.
Is it possible to share both the Pi4 and Theater4 speakers plan?
How about the crossover plan for the both the speakers?
I'll be using B&C DE250 for HF.
Re: Pi 4 speakers questions [message #51915 is a reply to message #51911] Fri, 14 March 2008 11:11 Go to previous messageGo to next message
Wayne,
Totally unscientific, but I was able to downsize my oversized 4Pi boxes by lining the interior with styrofoam insulation. Seems to
have worked out OK. Light weight, plenty solid, reversable.
Chris
You've got mail! [message #51916 is a reply to message #51914] Fri, 14 March 2008 13:59 Go to previous messageGo to next message
Thanks!! [message #51920 is a reply to message #51916] Sun, 16 March 2008 10:52 Go to previous message
Thanks you Wayne
Previous Topic: what can i do with a pair JBL 2206H woofer
Next Topic: 12PI
Current Time: Mon Nov 02 16:38:28 CST 2026
