Home » Sponsored » Pi Speakers » Wayne, crossover and L-pad confusion
What about 16ohm drivers [message #51854 is a reply to message #51850] Tue, 26 February 2008 14:18 Go to previous messageGo to previous message
Kim Schultz is currently offline  Kim Schultz
Hi Wayne.
I use Altec 902-16HF drivers in my front and center PI7 speakers, this is the normal 902 driver with a 16ohm voicecoil.
After playing around with Spice and measuring the driver with the crossover, I arrived with these values:
R1 = 33ohm
R2 = 12ohm
C1 = 0.22uF
This gives a load of about 9.5ohm on the crossover, where the normal lpad with the Eminence driver, gives a load of about 9.4ohm.
All good so far, but I really can´t seem to remember how to calculate how many db´s this lpad is damping.
Do you have another chart for 16ohm drivers on hand ?
I have another question regarding lpad with topend compensation.
After much consideration I have bought four Eminence Beta 8A drivers, and eight BMS4524 drivers with 18Sound XT120 horns for my bipole surround speaker project.
I will be running the BMS4524 drivers in series for a resistance of 14-16ohms.
Can I just use the same lpad as above (if the sound levels match), or are there a better way to do this ?
I was thinking of using a single coil on the woofer, and a third order crossover at about 2200hz on the hf drivers.
Btw, these drivers are excellent, they sound really nice and the horns are good too.
Previous Topic: Mounting Eminence Driver
Next Topic: midbass horn
Current Time: Sun Nov 29 17:06:07 CST 2026
